It is currently Thu Sep 18, 2025 7:23 am
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Spraying Enduro-Var
PostPosted: Thu Mar 04, 2021 6:46 pm
Last Name: Ball
bcombs510 wrote:
Great info, Dave.
You mentioned waiting 15 days next time. From my experience with Endurovar a few degrees can make a lot of difference in the time. If I left the instrument hanging in the basement which stays right at 68 degrees it took significantly longer than moving it upstairs into 70 degrees. I don’t know if others had the same experience but it shaved a couple days off.
Thanks for the info--I'm definitely working in out-of-spec temp/humidity right now, but it still did well. I think a little nip of reducer in the mix would probably have taken care of the orange peel (which still wasn't that bad).
I moved the guitar into my music room which is a few degrees warmer than my shop (still only 65 or so) for curing and after 10 days, it was definitely hard enough to buff out. Very very hard and brittle too. Good signs from my point of view--a lot like shellac but harder. What I'm not sure about though is the bond to the wood. I had a little chip lift up around where I cleared out for the bridge and I wondered if maybe that bond might improve over a longer period of time. Someone earlier mentioned having the finish delaminate on a neck after a while. Hope that's not going to be the case for me. But as much of this stuff as there is on furniture, floors, stairs, etc., I think if there was any major adhesion to wood issue (other than on top of anything but bare wood), we'd probably have heard about it.
These users thanked the author ballbanjos for the post: bcombs510 (Thu Mar 04, 2021 7:07 pm)
PostPosted: Wed Mar 10, 2021 8:05 am
Last Name: Ball
Update--here's a link to the finished guitar.
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=54006
PostPosted: Fri Mar 12, 2021 2:37 am
ballbanjos wrote:
bcombs510 wrote:
Great info, Dave.
.............................. Someone earlier mentioned having the finish delaminate on a neck after a while. Hope that's not going to be the case for me. But as much of this stuff as there is on furniture, floors, stairs, etc., I think if there was any major adhesion to wood issue (other than on top of anything but bare wood), we'd probably have heard about it.
I did adhesion tests with EV - 3 coats, dry, heavily cross hatch with a knife, press on duct tape, rip off - no issues at all. That was on satinwood, with and without Zpoxy.
Users browsing this forum: Bing [Bot], doncaparker, Gary Davis, Glen H, rbuddy and 34 guests
